Cross Spider In Polarized Light
Perl
Post by Perl »
Picture taken with Coolpix 4500 via Eyepice
Microscope was Ortholux II wit Pol Util
Regards
Pär Lundqvist
SwedenImage
Seems as though we are or have been seeing a lot of "fang" shots here of late on the forums or maybe it is just my phobia of spiders getting in the way :lol: Quite a colorful image and those fangs do look painful. :D
Perl
Post by Perl »
Hi Ken !
But i mostly do Single shoot of the objects only ,
dont like to use the hokus pokus image manupulations
tools and techniques
Do it more in Science way
Regards
Pär Lundqvist
Sweden
Pär,
Single shot is a great time-saver if what you want to see shows well when squashed flat.
About this picture, it's very colorful but I don't know what to look for in it.
What features are you interested in -- from a science standpoint -- and what information is brought out by the crossed pols?
Perl
Post by Perl »
Hi Rik !
Are in to the idea that diffrent chemical compunds
can be identified whit POL Mikroscope and Spectroscope
mounted to the microscope
Like Mineral identification in Standard POL Applications
but this is showing that same can be done on Biological prep to
This particular picture show distrubution of these
Compounds
Regards
Pär
Interesting. So are the red areas different from the brown due to different compounds, or different orientations of the same compounds, or just different thicknesses? How about the bright white tips on the fangs?
Perl
Post by Perl »
Hi Rik !
Yes Brown , Red and White are diffrent Chemical Compounds
Is show clearly when polarizer are rotated
The diffrent coulor show distrubutions of Chemical Compounds
in the spider , my idea is that what is done in Optical mineralogy
also can be used in Living thing
Some things have been done in the area , but this is not much
explored yet - much most be done in this , but it will sure be
a intressting area in future
Regards
Pär Lundqvist
Sweden
Pär,
I'm a big proponent of checking out some of these small "critters" with crossed polarization. Often it does not reveal too much, but sometimes, as in your picture here, it dramticaly delineates certain structures. I generally think of it revealing structural composition, so it is interesting hear that it may be of some use for actually determining some "chemical" composition characteristics as well.
A few subjects I have found interesting with this method can be seen here.
Hope to see more of your images!
Charlie
bernhardinho
Post by bernhardinho »
Hello Pär
nice picture!!
But I'm a bit amazed about your statements there!! Are you doing this professionally? Because I'm certainly willing to learn, but to my knowledge, birefringence in biological objects doesn't have anything to do with chemical compounds!! Apart from the fact that cellulose is optically active, birefringence here is solely due to structural features of the tissues paralleled fibres. Different interference colors are partly due to different thickness of the object and partly to the orientation of the object in reference to the crossed polars ( may be you have heard of so called additional or substractional position).
Best wishes from Germany and a happy new year!!
Bernhard
Raul G
Crosspolars on Tissue
Post by Raul G »
I also believe cross polars on tissue is a great thing, you must remember the calcium oxalate crystals on Paramecium or the chlorochromes on Pediastrum or Scenedesmus.
Cool img Pär ! :D
Perl
Post by Perl »
Hi !
This is just an Idea , that i have to look up closer
The preparations are flat mounted between glas
Have read some papers with Pol analysis on bioligical
preparations that work
Pol light have diffrent look then it pass diffternt crystal
structures in preparations , so i think this work on Bilogical stuff to
Do not work with this profesonaly , worked before with EM and
3D analysis on Virus structure
This is just for fun and to expand limits of whats possible
with light microscope , are much in to the tech stuff on microscopy
Will test and work more on this coming year - have some thinking
about analysis that can be done fast and easy with this
Can share my results here if intrests of others in this ??
Best Regards
Pär Lundqvist
Sweden
bernhardinho
Perl wrote:Hi !
The difference of why doublefraction and birefringence occur in crystalls and in biolocical "stuff" is fundamental!!! May be it is a good idea to read about crystall optics as well :wink:
By the way: how many different chemical compounds would you expect in a spider? It is mainly chitin (optically active) and muscle fibres (parallel structure) that cause interference colors!
Bernhard
Perl
Post by Perl »
Hi
To see optical diffrences are only half the idea , the other half
is to use a spectroscope to got more info out from the structure
Thinks this is an intressting track , due to its fast and simple
analysis setup - compared to other techniques
Perhaps its a dead end street - but sure worth looking in to
Regards
Pär Lundqvist
Sweden
Post by Mike »
Hello all,
Not sure how you come to the conclusion the different colors represent different chemicals - could you explain?
Cheers,
"Nil satis nisi optimum"
Perl
Post by Perl »
Hi
If different chemicals not represent diffrent coulor in Pol light
what is the diffrent Coulor then represent ??
Pär Lundqvist
Sweden
