100X objective tests
Olympusman
Post by Olympusman »
Testing 100X objectives on a metallurgical scope.
First a baseline 40X stack
100X dry objective
And the big surprise - 100X oil objective
Is the oil objective used dry here?
Can you be more specific about which objectives/tube lenses you are testing? Thanks.
Olympusman
Objective test
I should have put the specs of the objectives in the original post, which I will do from now on. The objectives are:
NIKON MPlan 40 0.65 210/0
The dry 100x objective may have come with an Amscope kit.
100/1.25
160/0.17
The 100X oil is a SWIFT objective that I have previously tested against my other oil objectives in transmitted light microscopy. This was the first time I tried it on a metallurgical scope with immersion oil and am very impressed by its performance.
SWIFT S-MICRO
100 1.25 Oil
160/0.17
100/1.25
160/0.17
NA 1.25 is an oil immersion objective for sure. The maximum NA attainable in air is 0.95 (and with water immersion 1.2, I think).
Not surprising the bad results without oil
