Illumination through ping pong ball and Zeiss fiber optic illuminator.
The wings of most insects are mainly composed of two layers of transparent chitin compressed to a single membrane with a refractive index of approximately 1.57. In air, these dimensions are ideal for two-beam thin film interference, whereby light beams reflect from the upper and lower surfaces of the membrane. The thickness of the composite chitinous membrane varies with the topography of the wing, and the areas of different thickness reflect different interference colors that together produce a specific color pattern, the WIP.
