Trachelius, details
- Charles Krebs
Trachelius, details
Looking through a large sample dish I found quite a few large colonies of (what I believe is) Carchesium. It was interesting to see that in several instances there were more than one Trachelius cruising around inside these colonies. After seeing this on a variety of occasions on different days is seemed obvious this was where they preferred to "feed".
I separated some and took a few "typical" shots. There was one specimen that presented me with a view I had not seen before, and that I think must be the oral cavity. I took some surface shots with the 60/1.40 to get a better look at that region.
- Ernst Hippe
Spectacular! A wonderfully detailed exploration of a weird critter.
That big cavity in the middle of the cell is not the mouth. It's an organelle called the "fossa". Nobody knows what it's for. The mouth is quite small, but visible in the second image, at the base of the proboscis.Mouth like a whale
It Came from the Pond (Blog): http://www.itcamefromthepond.com/
- carlos.uruguay
- Charles Krebs
Thanks for the comments!
Bruce... thanks for the information on the fossa. I wasn't aware of this feature even though I have observed Trachelius ovum before.
Not much about it that I can find, but it appears to be a determining characteristic for this species:
https://www.ncbi.nlm.nih.gov/pmc/articl ... 1/#bib0040
I'm usually hesitant to name a protozoan down to the species level... but we can certainly see the "fossa" and the "many scattered contractile vacuoles" in the last three photos... Trachelius ovumOrder Tracheliida. This order contains a single species, Trachelius ovum, which is defined by three apomorphies: (i) a club-shaped internal oral basket; (ii) a lateral fossa with specialized ciliature; and (iii) many scattered contractile vacuoles.
*duplicate post...see below
*duplicate post, see below
