Freshwater bryozoan
- Charles Krebs
Freshwater bryozoan
I was dragging my small plankton net through some light vegetation in one of my favorite fresh-water marshy areas. I thought I had dragged in a small rock, but on examination is was a bryozoan colony about half the size of a golf ball. WOW... what an overwhelming subject to work with! Tricky though. It's real beauty is seen when it is "unconstrained" and moving freely. So far I have only tried shooting with the entire "blob" placed in a small container on the stage, and illuminated (mostly) from above using electronic flash. Stacking is not really an option... constant movement, so DOF is a real challenge. But it can lend itself to some attractive shots if you try to use the in-focus pieces to emphasize the the graceful lines of this subject.
Beautiful!!
Troels
Troels
Visit my Flickr albums
- carlos.uruguay
- Charles Krebs
Thanks all for the kind remarks. This is a very photogenic subject!
Nothing special here at all. I tried to get "fancy" and played around with some different lighting set-ups, but ultimately the best results were when I simply pointed a direst flash at about 45 degrees onto the subject from a few inches away. The background is just the "blob" under all of the individual zooids.Saul wrote:please share background lightning technique .
Thanks,
Bryozoans
Beautiful, and those green copepods are a nice bonus.
