I've been experimenting with the color Heine condenser and I previously showed Rheinberg and color phase contrast images. The primary purpose of the condenser is, I believe, to generate color phase contrast. Here is a comparison between the condenser being used to generate a phase contrast image and then a color phase contrast image. If anyone has an instruction manual for this condenser, I would be most appreciative for leads on how to obtain it.
When you look at the back focal plane of the objective with a phase telescope, you will see two glowing concentric rings. If the filter is installed, the inner ring glows green and the outer ring glows red. The inner ring can be sized to fit the phase ring of a phase objective. The outer ring can be enlarged so it disappears from the back focal plane. In other words, this cone of light lies outside the N.A. of the objective. So, in essence you have a mix of phase contrast (green) and darkfield (red). If you displace the inner ring so that is not coincident with the phase ring, then you achieve what is the equivalent of Rheinberg illumination.
Most of my experiments have been restricted to an Apo N.A. 0.70 Pv objective by Leitz. Eventually, I will start working with the 70x N.A. 1.15 Pv objective and use the oil cap with the condenser. Presently, I am experimenting with different color combinations. For Rheinberg illumination my best results have been obtained with the 25x N.A. 0.50 objective.
