Frontonia acuminata ciliate
fpelectronica
Post by fpelectronica »
Hello
A ciliated I think, without security, it could be Bryometopus.
I appreciate help in correctly identifying
http://youtu.be/zdiUiRShYoE
Francisco
Bruce Taylor
Post by Bruce Taylor »
Hi, Francisco. It's Frontonia acuminata (a lemon-shaped Frontonia, similar to F. atra but usually smaller, with a pointed posterior and dark pigmentation confined mostly to a spot in the anterior). F. angusta is similar in size, but typically lacks the dark spot.
The mouth is visible at several points. You can see the paroral membrane flapping at 0:03, and the shape of the mouth is clearly visible at 0:56, right after the defecation (which seems to occur via the postoral suture...very interesting!) :)
It Came from the Pond (Blog): http://www.itcamefromthepond.com/
Very nice
Bruce Taylor
I took a couple of stills from your video, to point out certain features.
Some identifying characters:
Frontonia are equipped with excretory pores, but this fellow seems to be defecating through the postoral suture.
fpelectronica
Thanks Bruce
I correct the title.
Thanks Jacek.
Protos
Post by Protos »
Excellent as usual !
F. acuminata seems to be common at this period of the year . I see it often and other people as well.
Phil
Zeiss Axiophot, transmitted and Fluorescence
BK5000, Transmitted and CP
Wild M20
fpelectronica
Thanks Protos
escocat
Post by escocat »
A great video :D
fpelectronica
Thanks escocat
Francisco
