Euro Star (not the train!)
One star from an one euro coin.
This is my first shot testing epiillumination with the microscope
Zeiss Standard 18, very old Leitz epiiluminator, Zeiss Epiplan 8/0.2, cross polarizaion with Antiflex cap (1/4 lambda) over the objective, 10W LED light, Canon EOS 7D
Stack of 36 frames with CZP
Nice picture!
Nice
Thanks, my friends
Now, testing with reflected DIC (Inko in the old Zeiss nomenclature), same objective but with a Zeiss epi illuminator and more Köhler like tungsten light source
It shows nice colors but the hairline reflections fool the stacking software resulting in many artifacts.
Protos
Post by Protos »
You are the Star !
Making me interested in money ;)
Zeiss Axiophot, transmitted and Fluorescence
BK5000, Transmitted and CP
Wild M20
I partly understand what a ¼λ plate does, but would love to see the effect on the image. Do you happen to have an image with the polarisers but without the plate? The first image is quite thought provoking.. :-k
Protos, thank you :D
Chris, the effect of the antiflex filter (rotatable 1/4 lamda plate placed between the objective and the subject) is just to supress flare.
The first image is taken with crossed polarizers (one at the illuminator before the beamsplitter and the analizer between the objective and the microscope head). Turning the antiflex cap you can go from typical cross pol image (almost black) to a brightfield image but with less flare. The image was taken at that "brighfiled" position. It seems that this effect is more important with lower power objectives, my antiflex is designed for a 1.25X Zeiss.
Unfortunately I didn't shot any image just with cross pol and now I've dismounted* the system and I don't plan to remount it in at least one month, but the cross pol image is pretty black because the metallic direct reflection is effectively supressed and you only see dirt, oxidation and reflections provided by scratches (maybe from some angles related with Brewster angle(?))
*I needed to dismount the stage and condenser to be able to acomodate the epi equipment, I'm designing an open microscope with much longer clearance with parts of my macro setup and Zeiss microscopes I already have but I need to custom make a part and my machinist is always very busy.
Thanks Pau.
I need to find something which explains why a lambda plate is different from/better than having just the analyser but at some intermediate extinction position. The way the surface textures show is very appealing.
OK, Wikipedia and the usual manufacturers sites. May take some time ;).
There was some discussion at the forum:
http://www.photomacrography.net/forum/v ... t=antiflex
http://www.photomacrography.net/forum/v ... f6381d8eaa
g4lab linked to this article
http://zeiss-campus.magnet.fsu.edu/arti ... ected.html , towards the end of the article (but they propose a partially different use)
More info:
http://books.google.ca/books?id=E2maxdE ... 22&f=false
