Diatoms from a fossil bought on Ebay
Beatsy
Post by Beatsy »
A fossil leaf recently offered on Ebay was described as being 'on diatomite'. The seller said it came from the Massif Centrale in France and as I'm always looking for new diatom samples I bought it in the hope it might contain something interesting.
A marble-sized chunk was put through 10 freeze/thaw cycles to create a fine sludge. I then examined a few drops of the diluted sludge under the scope to get a preview of what was in there. It was immediately obvious the sample was overwhelmingly dominated by a small centric species - possibly Cyclotella (but I'm not sure). However, a (very) sparse smattering of other species warranted moving on to a full clean to see what else could be found.
After the usual acid treatments, rinses and silt separation stages, I ran the cleaned sample through a fine mesh that let material of 30um or less pass through and held back anything >30um. The fine material (mostly cyclotella) covered the bottom of a 250ml beaker in a 1mm thick layer but there was only enough larger material to make a single strew!
As discovered from examining the sludge, the fine material was pretty much all Cyclotella (?) but with other species sparsely dotted around.
The coarser stuff proved to be nearly all (freshwater) diatoms too, though most were pretty battered. I was able to pick out a few good 'uns though, enough for a small quick and dirty mount. Strangely, I found no sign of two of the species photographed when previewing the uncleaned sludge!? They must be very rare in the sample, but there are probably more in the unprocessed rock.
So no vast array of exciting species; I could find most, if not all of them in the local pond. But an interesting diversion all the same.
75RR
Post by 75RR »
Thanks for your report. I found it fascinating.
Great photographs of the Diatoms as well.
How old was the rock?
Beatsy
Post by Beatsy »
Thanks 75RR. I don't know exactly where in Massif Central the sample came from so it's tough to date it.
The forms found look practically identical to 'modern' species and there were many well-preserved pollen grains (pinus) in the unprocessed sludge. Given that, it could be sub-fossil material 2k-20k years old. But that is just a poorly-informed guess and may be wildly wrong.
Cheers
Beats
JH
Post by JH »
Fascinating! Is there a good book or article you can recommend that more in detail explains the process from stone to microscope slide.
Regards Jörgen
Interesting report, I like the details on last one.
Beatsy
Post by Beatsy »
JH: first link for a method of cleaning, second link for mounting. Hope that helps. Cheers.
http://micrap.selfip.com:81/diatomiteclean/catalog.html
http://www.microscopy-uk.org.uk/mag/ind ... atoms.html
Impressive!
JH
Post by JH »
Beatsy
Thank you for the links!
Regards Jörgen
