Unknown egg masses... any thoughts on (rough) ID
These were found floating on the water surface of a pond sample. Eggs are in a gelatinous mass, each egg itself had a "textured" surface as seen in the first image.
I don't recognize it... any thoughts as to what they might be?
(Images are all darkfield with 4X, 10X, 20X, and 40X and 1.67 NFK photoeyepiece).
Incredibly well done. I cannot help with an ID but they sure are pretty. Looks like fortune cookies.
Do not know what it is, but the pictures beautiful
Post by arturoag75 »
Great shots :wink:
Ichthyophthirius
Post by Ichthyophthirius »
Hi Charles,
They appear to be arthropod eggs (segmentation is visible), but I have no ID either. They trick, of course, is to wait a few days and to see what hatches :D
Olympusman
Egg masses
Post by Olympusman »
Charles, Nice find whatever they are.
Lovely set!
piermicro
Post by piermicro »
Great as usual.
_Michal_
Post by _Michal_ »
Fantastic set, as usual.
Best regards
Michal
Greenfields
Post by Greenfields »
Absolutely gorgeous images.
I apologise if this is a naive question to those who are familiar with darkfield technique, but have these been made using a vertical illuminator or with a darkfield condenser, please ?
Henry
Feel free to edit my images.
Thanks for the kind remarks!
These were taken using a dry (0.8-0.95) darkfield condenser.
Keeping an eye on them... I'll post if and when they develop into something more recognizable.
I am curious to the dry darkfield condenser you are using for 40x/0.95? I had to purchase the U-DCW which is an oil darkfield condenser to get DF at 0.95 NA. The U-DCD stops at 0.8 NA.
Waldo...
I also need to use an oiled darkfield condenser for the 40/0.95 S Plan Apo.
For this I used the 40/0.70 S Plan Achromat. This has the same NA as the 20X S Plan Apo (0.70) so there was likely very little (if anything) to gain over just cropping into a shot made with the 20/0.70 other than lower overall noise because I made use of the full sensor. Inherently not a lot of fine detail in this subject at this stage, and especially so when looking "through" the gel and egg casing.
Super!
(as always)
