Beetle larva, isopod...ID assistance needed
I've been determined to get outside and photograph "spring" rather than spend another one inside peering through the microscope. But I have been fooling around a little with polarized light, and the way it can show muscle structure. These two subjects worked out nicely, and I would love to get a little more detailed ID if possible.
The top is, I believe, a water beetle larva. But it was much smaller than the ones I have observed before, measuring only about 2.5-3mm overall (the back end is cut off in this shot, what you see here is probably just under 2mm). Is this just likely an early instar of one of the ones I usually see farther along and much larger?
The second is a section of a very common isopod I find in my pond. Looks like a tiny shrimp and are usually about 2-5mm in total length. I've photographed them often before, and would like to be able to call them something a bit more specific than simply a "fresh water isopod"
Any thoughts in narrowing down an ID just a bit would be appreciated.
Great! :smt023 Amazing details. :shock:
If Betty will not help with ID, nobody will. 8)
Post by Planapo »
Charles, gorgeous pictures as always! #2 shows amazing detail, especially the contours of the exoskeleton and the muscles.
The first picture looks to me like a larva of a hydrophilid beetle (Coleoptera: Hydrophilidae), but I could be mistaken. And you´re right about size varying with instar.
For further ID you could, (and that´s the way I myself would go)
a) ask a friendly specialist on water beetles who may, due to experience or access to literature, be able to say more even from looking at photos, if the photos show the crucial structures.
b) search for the literature, i. e. a published key on water beetle larvae that covers your region in order to figure it out under the scope yourself. This might be tricky as possibly such a key is hard to find because it´s older and not digitally referred to, or the one you find is outdated, or there is no key because yet no one has written one on these larvae (most keys on insects refer to structures of the adult forms), or...:( ... so, you see if you wanna figure it out yourself, you should go back to a) and ask the friendly specialist about such a key. :D. See, parasitizing colleages is often the most parsimonious way. :wink: :lol: No, just kiddin´. Honestly, I prefer reciprocal altruism.
(I can name North American specialists on (water) beetles who you could ask, if you want me to.)
The second picture: To be honest, I think most biologists won´t be able to say it´s a fresh water isopod (Crustacea: Isopoda) from this section only :D . If a fresh water isopod was from my place in the Western Palaearctic region further ID wouldn´t be to difficult since there are not many species of fresh water isopods. Possibly, in your place in the Nearctic region fresh water isopod diversity is also low and scientific literature with a key should then allow further ID easily.
Hope this helps a little bit.
Cheers,
Betty
Post by Wim van Egmond »
Charlie, great images!! I understand spring is a time to be outdoors. But good to see that you don't forget us and post some images!
Could it be an amphipod? Like Gammarus? They are laterally compressed and your image makes me think this is the case. But I could be wrong.
Wim
Could also be you who did the lateral compression :)
Wim
Betty and Wim... thanks for the replies. Being a little on the lazy side I posted them here first in hopes of gathering some direction towards ID's. Can't devote a great deal of time to it right now, but some quick follow-up on your suggestions indicate you folks know your stuff! :wink: (But we already knew that!)
The larva looks like a good candidate for the family Hydrophilidae, which is a good start.
The tiny shrimp is indeed laterally compressed (but not by ME! :D, I use a thin nylon washer between slide and cover just to avoid that!), and is an amphipod... possibly Gammarus fasciatus.
So thanks again.
