Water Mite
Olympusman
Water Mite
Post by Olympusman »
This latest pond dip is very rich in water mites. From what I have read, the environment of the pond is ideal.
Here's a trick you might find useful: When you have narcotized the subject, it may not be aligned to get the best coverage on your sensor. Remove the slide from the mechanical stage, put a blank slide on the stage and then put the specimen slide on the blank slide. This will allow you to rotate the top slide and still use the X-Y movements of the mechanical stage.
vasselle
Post by vasselle »
Hello
Very nice photo :smt038
