Diatom, Algae and Stentor Ciliate
For those wondering, GTF is simply an abbreviation for the location where I collected these specimens. Oh by the way - Charles, the stentor ciliate photos were taken at ISO3200 - something the 600D would never achieve with that little noise. A good example where my setup without flash benefits from the 6D's larger sensor and my ability to crank up the ISO to try and stop motion on the cirri.
20140531-DSLR_IMG_0037-Edit.jpg by pwnell, on Flickr
GTF - diatom,60x/1.2x*1.25, DIC, HF B
20140531-DSLR_IMG_0104.jpg by pwnell, on Flickr
GTF - Stentor ciliate,40x, DIC
20140531-DSLR_IMG_0105.jpg by pwnell, on Flickr
20140531-DSLR_IMG_0117-Edit.jpg by pwnell, on Flickr
GTF algae,20x, DIC, HF B
20140531-DSLR_IMG_0224-Edit.jpg by pwnell, on Flickr
GTF algae,60x/1.2, POL, HF A
_Michal_
Post by _Michal_ »
Great, as always :D
first image marvel
Post by arturoag75 »
Great...i' m impressed by your 60x water obj. :shock:
Marek Mis
Post by Marek Mis »
Very nice images. The quality of the first one is incredible !
By the way, what factors suggest you to choose HF "A" or "B" ? What does it depend on ?
Marek
Nice set!
The noise on the 6D is lower than 600D?
arturoag75 wrote:Great...i' m impressed by your 60x water obj. :shock:
Thanks, me too. The big thing about the water objective is that I can use it all the time and get much greater resolution than with the 40/0.95 alone. Unlike the 60x/1.35 which is technically better (for ideal samples and 0.17mm coverslips) but for which I need to use oil which makes a huge mess.
Marek Mis wrote:Very nice images. The quality of the first one is incredible !
Thanks Marek,
By now I am quite tuned to which method works best for which kind of illumination. HF B works best most of the time, especially for DIC. HF A works best when there are bright highlights or a challenging subject. HF C works best for fluorescence. But the rule is not set. My approach is per above, and if the result is not what I want I'll try the other methods and pick the best.
RogelioMoreno wrote:Nice set!
Thanks. Yes, by quite a large margin. With the 600D (APS-C) at ISO 3200 the noise would have destroyed much of the cirri on the ciliate's body. With the 6D (Full Frame) the details are all still there.
TasMan
Post by TasMan »
These are great pwnell, I especially like the one of the diatom. I have a "newby" question though, how do you get the backgrounds so uniform and clean? Is it done in post? If so do you have any tips how to do it well? I seem to end up with a lot of distraction in the background of my photos that is nearly impossible to get rid of :-)
vasselle
Post by vasselle »
Very nice photos
TasMan wrote:These are great pwnell, I especially like the one of the diatom. I have a "newby" question though, how do you get the backgrounds so uniform and clean? Is it done in post? If so do you have any tips how to do it well? I seem to end up with a lot of distraction in the background of my photos that is nearly impossible to get rid of :-)
Thanks. It depends on the subject. For instance, the ciliates I barely did anything to the background - that is pretty much directly from the camera. Same with the diatom - I did not touch the background. But the algae DIC photo had lots of disturbing elements - especially caused by small swimming protists that wreaks havoc with the stacking algorithms so there I cleaned the background in post.
Very nice!
