Typically they intercalate themselves into the crevices of rocks and I can't pry them out without cutting them up into pieces that will regenerate into more Aiptasia. But this one wasn't so clever and adhered to an old shell. I was able to let it expand in a small petri dish of seawater and then rapidly pipet nasty Bouin's fixative over it, fixing (well, that's a nicer term for it...biology is the art of killing with finesse...) it before it could contract completely. It was then washed to remove the Bouin's, dehydrated in ethyl and isopropyl alcohols, and embedded in polyester wax. I sectioned it at 5 microns on my 1935 Spencer microtome. The sections were stained with the simplest of the Mallory trichrome protocols; I am going to try the more elaborate and supposedly better AZAN technique next. Photos all taken on the BX-60 using either 20X/0.7 UplanApo, 40/1.3 UPlanFl or 60/1.2 UplanApo objectives and standard thickness (U-DICT upper prism) Nomarski optics. The image was relayed through a Leitz Variozoom (5 to 12.5X) eyepiece, Leitz 0.32X converging lens to a D300s. I've shown some cross and longitudinal sections of a tentacle and some of the main body.
Results are interesting. You can see unexploded nematocysts as red-stained coils in the outer layer of the tentacles.
The first image is a low mag shot of a cross-section, you can see the outer layer of nematocysts, and the extended tubes of some of the exploded ones sticking out. The next 3 images show longitudinal sections of a tentacle. You can see the red nematocysts with their coiled thread tubes, muscle and other fibrils stained blue, and zooanthellae (commensual algae) and other structures and cells stained shades of purple, orange or blue. Nuclei are red to purple depending on the cell type. Following images are from the main body, which show internal muscular and elastic structures in blue along with ciliated cells on the inside of the body cavity and internal partitions of the animal's body.
I am puzzled by the fact that what I am interpreting as muscle is staining blue; for all mammalian and fish tissues I've stained using Mallory and other trichrome techniques muscle cytoplasm is red and only collagen is blue. Maybe cnidarian tissues are different. I am going to try a more sophisticated trichrome technique (AZAN) on more slides and see if
this holds. For now, there's at least one Aiptasia that I am actually glad to see.
David
