Cyclops sp musculature
gpmatthews
Post by gpmatthews »
Single unstacked shot
Sample prepared by fixing in 5% formalin, washing with 10% glycerine, dehydration with isopropanol (4 changes) and then mounting in clear epoxy resin.
Zeiss Standard Microscope
Ocular: Zeiss KPL-W 10/18
Objective: Leitz 16/0.45 ICT
Substage: Leitz ICT 0.9NA
Specimen from Warnham Local Nature Reserve, March 2014
Image processed to remove slight vignetting, which tends to occur with the x16 Leitz objective.
Graham
:smt041 :smt041 :smt041
Hindpool
Post by Hindpool »
Graham - that's a very fine single-shot anatomical portrait of a nicely mounted Cyclops. I like the slight bas-relief effect and presume that it comes from a degree of oblique illumination?
gpmatthews
The relief effect is due to using differential interference contrast (Leitz designation is ICT), rather than oblique illumination. This specimen was prepared as part of trying to develop methods of using clear epoxy as a mountant - working from scratch, really, as I am not proficient at mounting at all.
Graham
