EOS 7D with my hybrid DIC microscope
1. Video showing its light attraction. Leitz NPL Fluotar 40X 0.70
http://youtu.be/8s7mLePIDCA
2. Flattened under the coverslip. Zeiss Planapo 63X 1.4, more or less cropped:
Hope you like it
Pau i noticed this problem in an old topic ..you can see here:Pau wrote:Arturo, I'm intrigued with your bad experience with Leitz Pl Apo 63X. I was thinking on them for two reasons: most of my objectives and eyepieces are from Leitz and because its front lens is much wider than the Zeiss one, I think that the working distance will be too (what matters is the entrance angle...).
Did you used Leitz eyepices?, The blue halos are longitudinal CA?...I will like to see some pictures taken with them (and I would like to test one but...)
Pau wrote: The Planapo 63 1.4 160/- is BTW a good objective but not an easy one.
It's not necessarity a problem with the lens. The diatom sceleton also acts like a (silica) lens and can cause colour fringes that cannot be corrected by the objective. You can use green light and grayscale your image to get around that.arturoag75 wrote:...you can see disturbing fringes blu and Yellow.
-I didn't know about those 1.5H cover glassesIchthyophthirius wrote:The correct cover glass thickness should be No 1.5 (0.16-0.19 mm), not No 1 (0.13-0.16 mm). 0.17 mm is the reference cover glass thickness for all major manufacturers. That's why they also sell No 1.5H cover glasses (0.17 +/- 0.005 mm; actually for high NA immersion objectives; see below).
- Well, mine is an old 160 corrected objective and according to Zeiss literature from its age /- means to be used both with and without cover glass, so I assume that it is for homogeneus immersion ( but in the some booklet the 63/1.4 is marked as designed for 0.17 coverIchthyophthirius wrote: For dry objectives, any diversion from the 0.17 mm thickness results in spherical aberration. That aberration is worse for cover glass that are too thin, i.e. a thickness of -0.02 is much worse than a thickness +0.02 http://www.olympusmicro.com/primer/java ... spherical/ last figure.
The Zeiss Planapo 63/1.4 Oil is marked "160/-". The "-" does not mean "tolerant to variation of coverglass thickness from 0.17" but "tolerant to variation of coverglass thickness from 0.17 taking into account NA and magnification".
Modern oil immersion objectives don't use homogenous immersion any more. The refractive indices of cover glass, oil and front lens are all different. Therefore, cover glass thickness matters for high NA objectives, regardless of whether the object is embedded in water or resin.
0.01 is really small!, beyond the precision of most makersIchthyophthirius wrote:For objects embedded in resin (like histological sections; diatoms), variations of No 1-1.5 cover glass thickness don't matter (range 0.13-0.19 is well tolerated) with objectives up to NA 1.3, as far as I know. For NA 1.4 objectives like the Planapo 63/1.4, the tolerance is only 0.17 +/- 0.01 mm for best results.
I'll post Euglena images taken with the NPL Fluotar 50/1.00. They have good contrast and are easier to take, but not better resolutionIchthyophthirius wrote:Using a No 1 coverglass (0.13-0.16) in order to increase the working distance is OK, but you have to keep in mind that this is a compromise. Sometimes a Planapo 40/1.0 or Planapo 100/1.3 will give better images for objects embedded in water.
- I have one of these Pl Apo 100/1.32 170/0.17 but I can't get DIC with it. In fact I don't find it superior to the Leitz PL Fluotar 100/1.32 160/0.17 (again unable to get DIC in my system)Ichthyophthirius wrote:If you want to investigate diatoms embedded in resin on antique slides, you could consider the old Leitz Pl Apo 100/1.32 170/0.17 objectives (the old 170mm, not the new 160mm) which have an incredible working distance of 0.24-0.25 mm (vs. 0.09 mm in Zeiss)!
