Here a new Pleurotaenium ovatum and Cosmarium that I found few days ago. This P. ovatum is more clean that the last one I posted, the Cosmarium shows small holes.
#1: 58 frames with HF B, 20 x 2 = 40x on sensor
#2, 53 frames with HF B, 20 x 2 = 40x on sensor
#3, 18 frames with ZS DM (I had to do retouching with ZS), 20 x 1.5 x 2 = 60x on sensor
Waldo, with the 3 images I did:
- rotating (when necesary) and cropping
- color balance
- constrast adj.
- remove noise
- sharpening
- remove noise
All the above task took less than 5 minutes.
The final step is to clean the background to remove the artifacts created by the stacking software. The subject is never touched.
