Oblique brightfield with 10X S Plan Apo.
It was not a "dedicated" oblique condenser but my Universal condenser on the BH2. This has a rotating turret to move from brightfield to different (in my case DIC) inserts. If you have it in the brightfield position and just partially rotate towards a different position the aperture moves to the side and you can get the oblique effect. (When I used a Labophot I did the same thing with a multi-position Phase Contrast condenser). It is not as versatile as a "dedicated" oblique condenser since you are limited as to where you can position the aperture, but generally works out quite nicely.Did you use an oblique condeser?
