Auto Fluorescence + 3D Deconvolution - The Beauties (part 1)
Here are the first group of the beauties.
All images were done with the Plan Apo 20x/0.75 and the UV-2B cube with auto fluorescence. You have to do the stack quicly because the specimen auto-fluorescence get dim with the pass of the time.
Closterium by Rogelio Moreno G., on Flickr
Micrasterias laticeps by Rogelio Moreno G., on Flickr
Micrasterias furcata by Rogelio Moreno G., on Flickr
Micrasterias radiosa by Rogelio Moreno G., on Flickr
Fredlab
Post by Fredlab »
arf...
speechless
:shock:
I apologise for my poor english
My blog (Macro Micro World)
My gallery
Fascinating and beautiful results. Alas this could be yet another new way to drain the wallets of long suffering photomicrographers! :wink:
Marek Mis
Post by Marek Mis »
Rogelio,
Really spectacular images ! All of them are beautiful but my favourite is the 4 th one.
Thanks for sharing.
Marek
beautiful :shock:
Ernst Hippe
Post by Ernst Hippe »
Rogelio,
phantastic pictures of my beloved desmids!
The M.laticeps is not common over here - I got it only once from a supplier of tropical water plants, and only the variation with single tips at the side lobes. Where from did you get it and which variation(s)?
Regards Ernst
Ecki
Post by Ecki »
Rogelio,
this is amazing. I think I need deconvolution software as well ;) What package did you use?
Best regards
Ecki
discomorphella
Post by discomorphella »
Beautiful results. Now you need to figure out which antifade reagents are the least damaging to algae. You might try some dilute p-Phenylenediamine or DABCO (start with perhaps <= 20 micromolar in the water you use to mount the specimens and work up to larger concentrations if required) to try and reduce the photobleaching. Deconvolution results look great, can you please include some details as to which algorithm, how many slices, which model parameters etc that you are using?
David
Extraordinary quality, both this ones and your Spirogyra.
Litonotus
Post by Litonotus »
I'm sure we will see one of them in top 10 of small world or bioscapes (: great!
my FB page
4th one is in a class of its own.
Post by arturoag75 »
Really stunning and fascinating imsges.........
I' d like to know more on this tecnic :shock:
sebba28
Post by sebba28 »
Stunning pictures, :shock:
Thank you for your comments.
Ernst, I am getting my samples from lake Miraflores (this lake has some degree of salt because it is a reservoir for the Panama canal). If the specimen on picture #4 has double tips on the side lobes then I am finding single and double.
Ecki, I am using the 3o days trial of cellSens and AutoQuant X3.
David thank you for the tips about the p-Phenylenediamine, do you know where I can get it?
I am using the default settings on both cellSens and AutoQuant 3D deconvolution, no SA detection.
#1: 2322 x 1179 x 24 slides
#2: 2498 x 1339 x 14 slides
#3: 1851 x 1750 x 20 slides
#4: 1684 x 1688 x 23 slides
#5: 2061 x 2010 x 21 slides
#6: 2161 x 2073 x 16 slides
All with the Plan Apo 20x/0.75 and 1 um step.
Ecki
Post by Ecki »
Hi Rogelio,
I looked at AutoQuant X3 and was very impressed. Do you know how much it costs?
Regards
Ecki
