Auto Fluorescence + 3D Deconvolution - Set 1
I have been testing the trial versions of cellSens and Autoquant X3 to try to get better resolutions from my fluorescence stacks.
With each specimen stack you have to try all the projections that the software gives (Sum, Max, Mean, EFI) and you as artist have to choose the one that you like more. Not all the specimen gives better stack than the one you can get with stack software as Zerere or Helicon.
The following is the first set of the results. In the coming days I will publish the beauties set (Micrasterias, Closterium and Pediastrum).
Spirogyra by Rogelio Moreno G., on Flickr
Butterfly scale by Rogelio Moreno G., on Flickr
Rotifer by Rogelio Moreno G., on Flickr
Phacus by Rogelio Moreno G., on Flickr
Litonotus
Post by Litonotus »
first one is outstanding! I can hardly wait for more.
my FB page
pierre
Post by pierre »
Impressive results Rogelio :shock:
Regards
Pierre
Marek Mis
Post by Marek Mis »
Very interesting and impressive images !
Marek
Yes, impressive. The spirogyra is beautiful.
Post by arturoag75 »
:shock: :shock: wow
René
Post by René »
Stunning indeed, Rogelio!
René
Fredlab
Post by Fredlab »
First one is incredible.
Thanks for sharing.
I apologise for my poor english
My blog (Macro Micro World)
My gallery
Thank you very much for your comments- :D
:shock: :shock: :shock:
These are really good. How large image do you send to these applications? I found that Autoquant takes approximately 8 hours to deconvolve using spherical aberration detection a set of 40 x 110MB TIFF images at 5400 x 3500 pixels - this on a machine with 28GB RAM and fast 3.5GHz i7 processor.
Also, cellSens always crashed on me if any image stack had images larger than about 2048 x 2048.
Thank you for your comments.
Waldo, I have the same memory problem. Sometime cellSens crashed with Internal error. To avoid the memory problem I send 8 bits tif (instead of 16bits tif) to AutoQuant, then I crop the area of interest and finally a resize of the image (only if the amount of memory available is not enough to do the stack).
My dataset are normally around 2000 x 2000 x 24 slides.
Rogelio, Waldo,
Have you tried deconvolution with no fluorescence images like DIC or darkfield?. It may be great if it works
Pau,
I did try some DIC and polarized and I did not like the results (to ugly for my taste), I also did try a darkfield (I like more the normal stack version); but I have to try more darkfield because darkfield is like fluorescence.
