At the recent microscopists weekend at Juniper Hall in the UK, referred to by Graham, Chaoborus hunting became a bit of a popular sport, as the accessible water sampling points didn't contain a very rich array of organisms. Here are my efforts on this very attractive subject.
First some stitches of the whole creature. I made a couple of with X4 and X6.3 objectives, and one with a X10 objective which was over ambitious, but from which I rescued several usable crops.
Larger zoomable version here: http://photosynth.net/view.aspx?cid=7d2 ... ead019e145
All images are with a Zeiss Standard microscope with a Leitz X10 periplan used as photoeyepiece in a Pentax microscope adaper with a Canon EOS 40D attached via an M42 -> EOS adapter, using LiveView mode and a simple wired cable release. The first image used a Zeiss X4 planapo objective and was stitched from 38 images with Microsoft ICE. Illumination was partially crossed polars with a rotatable retarder made from a piece of cellophane CD wrapper.
Larger zoomable version here: http://photosynth.net/view.aspx?cid=33e ... 8494b133c2
The next image is a larger stitch of 68 images using a Zeiss Neofluar X6.3 objective. illumination was polarised light plus a perspex wave plate.
I then tried a stitch using a Zeiss X10, 0.30 planapo objective. This took 100 images for, I thought, full coverage, but when it was too late to repeat it, proved to have several missing sections. Nevertheless parts were recoverable as crops and were worthwhile. The first is a crop of the head section. Illumination partially crossed polars with cellophane retarder.
Larger zoomable version here: http://photosynth.net/view.aspx?cid=4f5 ... 9ce3fe829e
The paired anterior and posterior buoyancy 'floats' are truly fascinating organs. The anterior pair show up nicely in this tighter crop from the X10 stitch.
This is a crop from the middle portion of the abortive 100 image stitch.
Large zoomable version here: http://photosynth.net/view.aspx?cid=8ff ... 486815abf4
And this is the 'tail' end.
Larger zoomable version here: http://photosynth.net/view.aspx?cid=63e ... ac144f8b87
I will post some more images of the buoyancy organs and the head tomorrow.
