brightfield, objective 4x, nocturnal seaplankton
Franz
1.
2.
3.
4.
5.
6.
Thank you Charles. These are not stacks but single frames. My method: I take only very big copepods, more than 1 mm long (which I find in the nocturnal plankton), so I can use the objective 4x, but only in brightfield.They are trickier to photograph than would be expected. (Are these stacks or single frames?)
Franz Neidl wrote:I don't know about your equipment, but in some cases there are other approaches.Therefore I will have to reduce the magnification. The unique possibility which I have is to reduce the magnification of the camera.
- If you use an eyepiece in your camera setup (both as projective or as part of an afocal system) you can look for a lower magnification one. For exemple in my afocal system I have (approx) the same magnification with a 6.3X eyepiece in APSC as with a 10X with FF, and Charles do the same with a 1.67 projective with APSC as equivalent to 2.5X on FF.
- In an afocal system you can switch to a camera lens of shorter focal lengh
- In some microscopes with fully corrected objectives (or objective +tube lens combo) you can make a direct projection setup (1X magnification on sensor)
- some microscopes have a magnification changer with negative magnification like 0.8X
...but I guess you already had studied those possibilities
Hello Pau,Pau wrote "It would be as simple as an empty tube to place the camera sensor at the same height of the primary image inside your photoeyepiece."
