Hello,
just prepared a tick (Ixodes ricinus, adult male) for microscopy:
- keeping the tick f0r 24 h in Ethanol, 70%
- maceration for 24 h in 15% KOH
- 24 h in 80% Lactic acid for clearing and softening
- washed with water
- mounted in in Hoyers Gum
Hoyers Gum:
Aqua dest. (g): 3,3
Chloralhydrat (g): 13,3
Glycerin (g): 1,3
Gummi arabicum (g); 2
Chloralhydrat helps in clearing the dark chitin parts of the tick.
Stitch consisting of 3 parts, each part is a stack of 80 pictures combined with ZereneStacker, oblique illumination
Same tick after a ten minutes visit at Dr. GIMP :
A Tick
- ralfwagner
A Tick
Ralf
http://www.lichenes.de
http://www.dr-ralf-wagner.de
http://www.youtube.com/user/drralfwagner
Ralf
Great job of clearing and mounting the tick. I usually use PVLG instead of Hoyers, since in the USA is it a bit difficult to obtain Chloral Hydrate (its considered a controlled substance). I had a large Dermocentor tick attach itself to my neck a few years ago (very painful, not subtle at all...). After I pried it out of my neck, the miserable parasite suffered a similar fate to yours; clearing in hydroxide, then phenol/lactic acid and then into PVLG. Also congratulations to Dr. Gimp, who has miraculously cured the injured leg .
David
David
- ralfwagner
Hello,
ticks are really strange, indeed.
Chloralhydrate is a controlled substance in Germany, too. But you can still buy it at your local pharmacist if you explain to him for what reason you want to use it.
Ralf
Ralf
