With the 3.3X photo-eyepiece and the 1.2X of the fluoro intermediate piece your total relay magnification is 4X (3.3x1.2=3.96).
So with a 10X objective, the image was recorded at 40X on the sensor. This is where some people get confused. Since most folks are using 10X eyepieces, and thus for this example they are viewing at 100X (10X10), they sometimes will say the photo is 100X.... wrong.
Probably the most accurate
verbal description would be to say it was recorded onto a 23.6x15.8mm camera sensor at a magnification of 40X. Then (assuming no cropping) if someone wanted to do the math they could determine the actual magnification of the final (enlarged) image. But nobody really annotates their magnification that way. So it becomes ambiguous (and is something of a pet peeve of mine
) when you see a picture and it is simply labeled, say 100X. Where is that 100X? Through the eyepieces? On the sensor/film? In a 5x7 inch screen display? 11x14 inch print? This is why, if you really want to help the viewer get a sense of the subjects size nothing beats a scale bar. It does not matter how the image is displayed, you always have an accurate size reference.
I don't think a scale bar is always needed in a forum like this, but if the size of the subject is really important to appreciating the picture it is a good idea. Also, in a forum like this, I think there is often some curiosity as to what "hardware" was used, so it is fine to provide the objective magnification, and/or relay optics that were used, even though there are additional factors (sensor size, cropping) that will determine the actual picture magnification.
