Micrasterias thomasiana, divisions and some special views
myriophyllum
Post by myriophyllum »
some times ago I showed a video about the division of Euastrum oblongum http://www.youtube.com/watch?v=gzh5j3NJ5-Q.
Now the second part of my desmid divisions: A film of Micrasterias thomasiana var. notata. Some scenes have been recorded in time lapse (up to 125x).
You can watch the video here:
http://www.youtube.com/watch?v=0P7RQV51XvU
Some stills out of that video:
Bacteria on the string between two cells
The intercellular connections have in one scene (around 0:35) been pointed out by putting some chinese ink into the water.
An empty shell
And some moments of a division, it took about 4 hours from the first to the last image:
Illumination: Darkfield, phase contrast and asymmetric Rheinberg/Col mixture
Zeiss Standard 18; Planapos 4, 10, 25, 40 and 63 Ph; Ultrakondensor; Achr.-Apl. 1.4;
Kpl 20x/8; S-Kpl 16x/12,5; S-Kpl 10x/20.
I hope you enjoy it.
Greetings
Jens
These are great and very informative, thanks.
Excellent!!!
curt0909
Post by curt0909 »
Wow! Super job. I really appreciate the effort and time that went into making this. You're a master of Rhienberg oblique illumination.
Very informative.
Marvelous!!
I am grateful to you that you share videos and photos of this excellent work
carlos
:shock:
myriophyllum
many thanks for all Your comments,
I enjoyed them a lot. :-))
Greetings
Jens
harisA
Post by harisA »
Very beautiful images.
I would like to know how you take photos with the zeiss standard. I suspect that you have the trinocular head and you use a s-klp eyepiece.What additional lens are you using in order to project the image on camera sensor.
Also what camera do you have?
Thank you in advance
Haris.A
myriophyllum
Hi Haris,
thank You.
It's right, I use trinocular head and Kpl or S-Kpl eyepieces.
Then the image is projected by a Zeiss T2 adapter (0.25x) with 63 mm
lens inside onto the chip of a Canon EOS 5DII.
That works very fine for filming. :-)
Best wishes
Jens
harisA wrote:Very beautiful images.
Haris.A
Post by Wim van Egmond »
Very nice results. Since we usually observe microorganisms under a coverslip we often don't see how the mucilage forms a stalk. I have a petridish with M. thomasiana alive for more than half a year.
When you put them under the stereomicroscope you can see that it is almost like a forest of palm trees.
Wim
harisA
Post by harisA »
Thank you Jens for the info.
One more thing.Is there significant difference in image quality between s-kpl and kpl eyepieces ?
Haris.A
myriophyllum
Hi Harris,
i have owned both, the Kpl-W 10x/20 Br foc. and the S-Kpl 10x/20 Br.
With the S-Kpl You have less monochromatic image artifacts like
coma and astigmatism in the outer areas of the image.
So if You can use large fields the S-Kpl is the better choice.
I sold my pair of Kpl-W 10x/20...
Greetings
Jens
harisA wrote:Thank you Jens for the info.
Haris.A
