Identification please
flyer2o12
Post by flyer2o12 »
Can someone please identify these organisms?
http://www.flickr.com/photos/38484518@N ... hotostream
There were extracted from near the ponds surface here in Ireland.
Please excuse the awful quality of the movie, we do not have the appropriate adapters to mount the DSLR to the microscope.
Bruce Taylor
Post by Bruce Taylor »
At this magnification, it is difficult to say more than "speedy little ciliates." :) To me, they have a Prostomatean look (the mouth seems to be apical, and the swimming style & big vacuole remind me of certain Prorodontida).
flyer2o12
Post by flyer2o12 »
Hi Bruce thank you for your response. Those creatures you mentioned look like Coleps. These organisms definately do not look like Coleps though. I will post another movie soon of better quality.
Bruce Taylor
flyer2o12 wrote:Hi Bruce thank you for your response. Those creatures you mentioned look like Coleps. These organisms definately do not look like Coleps though. I will post another movie soon of better quality.
Prostomatea is a large group of ciliates, and few of its members resemble Coleps, with its lovely costume of epiplasmal platelets. :) I was thinking more of certain smaller members of Prorodon or Holophrya (or related genera with apical cytostomes).
Perhaps a closer view of the oral structures will help narrow things down a bit.
flyer2o12
Post by flyer2o12 »
Will scanning electron microscopy help you to id them? :wink:
Bruce Taylor
Anything that gives a clear view of the mouth would be a start. :) If it wears its mouth on one side, we're looking at a whole different class.
flyer2o12
Post by flyer2o12 »
Hi Bruce, I have uploaded two new movies of much better quality than the previous one and I plan on doing some scanning electron microscopy of them tomorrow. http://www.flickr.com/photos/38484518@N ... hotostream
Bruce Taylor
Well, there are certainly a lot of them. :) I'm looking forward to the electron micrograph!
I dug into your photostream a bit. The creature you recorded on March 07 is the same as the one you filmed on March 03: Stylonychia, probably S. pustulata. The caudal cirri are briefly visible at 0:53 of the 07 video.
A video, showing the anatomy of a Stylonychia from another Canadian pond: https://www.youtube.com/watch?v=rsjMSXarR3o Important groups of cirri are labelled.
The creature you recorded on March 20 -- round in cross-section, with big macronucleus, lateral cv and pigment spots -- might be Ophryoglena atra. Unfortunately, I was unable to find the mouth. :(
Ecki
Post by Ecki »
Probably not! After sputter coating you can not detect anything inside the ciliate - thus many ciliates can not be properly identified just with a SEM image. You need to make an image with a very high magnification (DIC) of the oral apparatus and identify as many features (cortex, nuclei, CVs etc) as possible.
As you have so many of those critters you can try the following:
Filter some of the water in which the ciliates are living now. Take 2 or 3 microscope slides with cavities (hollow grinding). Use a very fine pipette to take some critters out of your sample. Release them into the first slide and into the hollow. Fill it up with some of the filtered water. Observe under the stereo microscope. If there is debris with the critters, use the pipette again and transfer the critters to the next slide, fill it up with cleaned water. Repeat transferring them from hollo to hollow until you have the critters totally isolated. Then put wax or vaseline on the corners of a cover slip. Remove excess water with the pipette from the last hollow with your clean ciliates by pressing the pipette onto a spot where there are no ciliates - release the pipette. That way, the critters will not be sucked into the pipette. Remove unwanted water this way to concentrate the critters.
Now put the critters on a normal slide. Carefully attach the coverslip. You can control the thickness by using a little bit of pressure on the coverslip. Control this with the microscope. You can lower the cover slip until the critters are pretty much immobilized. You can put a drop of distilled water next to the coverslip. The wax prevents the coverslip from coming down further and you can keep this mini aquarium alive for a while.
This way you can make good photos and you can observe and note the details of your critter. Then identification is not so hard. Bruce will have a blast ;)
Regards
Eckhard
