Thanks for the clarification, so the axiopodia are acting like muscle fibers moving the glass spines? are they all attached together in the center?Bernd wrote:Excellent photos!
Just for clarification: The glass spines are attached to the surface of the heliozoon. It is the axiopodia that meet in the center of the sphere.
Bernd
Thanks Charlie, I think the organsms size helped. I corrected the terminology for the 2.5X NFK lens thanks for the pointer, it's always appreciated.Charles Krebs wrote:Very nice!
Rarely (if ever) have I seen the shapes at the ends of the spines as well as you capture them here.
Hi Jon. I've taken the first image as shot, with all its blemishes and warts, as it came out of the camera as a RAW file and shown it below. All I did was to reduce it in size/bit depth so I could post it. I also took a segment from the center and pasted it in the corner. As you can see there is significant CA. I reduce CA in photoshop and make the most of the available data. RAW files often need substancial work, and optical performance isn't always achieved as in this case with a mid range objective and a deep slide.Ichthyophthirius wrote:Excellent shots of this heliozoon!
I am also astonished by the quality of the image. I can't see any colour fringes; is this normal for Olympus Planachromats or have you applied some image processing to remove the fringes?
Kind regards,
Jon
