it works, I overexposed the image and the highlight is better, than I put together two images; problems begin when it will come to a stack...
(I'm guessing you meant "underexposed")
If you anticipate such a problem, it would not be that unusual to take separate stacks at different exposures (probably best to bracket at each step during initial stack acquisition) and then use the lighter or darker segments as needed (or go to an HDR method). Makes for a lot more work, but sometimes you just can't solve it with lighting.
If it is a high magnification stack where you know you will be turning off "re-sizing" in the stacking software, you can just go back and shoot the frames needed to record the the problem areas and stack and incorporate them as needed. This saves time and work if it is a very large stack and the trouble area is small. (For example, it is not unusual for me to do this with a small white patch of scales on an overall dark butterfly wing).
