Are you sure it is not a close up of your wind screen?
I'm sure it is a flatworm. The two eyes indicate that!
Yes, I have seen it happen way too often. It is not a pretty sight. We all have to deal with it. You are just too late and there is no way you can reanimate the poor thing. Microscopy is a cruel job but someone has to do it.
Although if the organism is not squashed yet adding some water to the edge of the coverslip may help .
But these two images do prove how important it is to create a very flat slide! The image quality is excellent, crisp details, much better than it would be with a thicker slide with a lot of water. So these images are very instructive. This flatworm has donated its remains to knowledge!
So it is always the trick to make the slide as flat as the organism. Without distorting them too much.
And that is a matter of timing. Ken, I know these remarks are a bit redundant, we all probably have the same experience, but I thought I'd mention this procedure in case some of you haven't thought about it: I first scan the organisms on my slide at low power and than I work systematically. While the sample slowly becomes thinner because of the evaporation of the water I start with the thicker organisms and I do the thinner ones later.
Wim
