Then I tried something to get a little different "look" to the tests. They were placed on a slide with no water or cover slip, and photographed on the MM-11 microscope arrangement used for "dry" subjects (#2 and 4). Lighting was from above using two Ikea LED lamps through large ping-pong ball diffusers, with things set up to give a darkfield type of illumination. The tests I gathered measured about 300x180 microns (0.012x0.007 inches) in size.
Olympus BHS, Olympus S Plan Apo 10/0.40. Brightfield with partially crossed polarizers. 20X on sensor. 14 image stack. (Image cropped)
Nikon MM-11. Olympus LMPLFLN 50/0.50. Reflected light. 50X on sensor. 85 image stack.
Olympus BHS, Olympus S Plan Apo 4/0.16. Brightfield with partially crossed polarizers. 8X on sensor. 11 image stack.
Nikon MM-11. Mitutoyo M Plan Apo 10/0.28. Reflected light. 9X on sensor. 24 image stack.
