beetleman wrote:Those dyes do a wonderful job of bringing out all the features on this cross section Bernhard. Do you have to do any pre-preparation on the slice before you stain ? Being a juniper (evergreen), did you run into any sap problems?
Hi
no, to the contrary: the stem was rather woody (if this is a word
). and hard to cut. The trick of the trade is to keep it in a 50:50 mix of alcool/glycerol for some days (NO Ken; I'm not talking about Gin.) Thus it gets fixed and softened at the same time. As the cuts still are likely to get a bit thick it's good to put them in a bleaching agence (Eau de javelle) to remove cell contents. It then needs to be rinsed in destilled water and it can then be dyed without further ado.
Bernhard
