Well I suppose "optical staining" (
http://www.olympusmicro.com/primer/java ... index.html ) sounds more official, but "Disney Color" works for me
(Sort of a derivation from of the name we lovingly gave to Fuji Velvia in the fim days ... Disneychrome).
If you are referring to the part indicated by the arrow:
That is another "branch" identical to the six that are shown, but it is pointed directly into the objective. In this case it was not broken off so I had to be very careful to use enough oil to float the cover slip above it. So what you see in the 20X objective shot is an optical cross section (it gets nearly completely blurred out in the 40X objective shot).
I tried your tip using cassia oil. A few years ago I did something similar with a high RI Cargille Refractive Index Matching Liquids (Series B I think, about 1.70 RI). It worked well, but the stuff was very expensive and did not have a long shelf life. GNC sells the cassia oil for aroma therapy so I thought hey... I'll get some needed therapy and take a few pictures at the same time. It advertised
"Benefits: Warming, stimulating, refreshing" (to which I will add, if you work over this stuff all afternoon in a hot, poorly ventilated room
"nauseating".
Really though it worked well, smells good, and is cheap. I'll use it more often.
Since I did float the cover to avoid breaking the subject I was expecting more image degradation than I experienced. I wonder if the slightly higher RI (about 1.60) helped in this regard. Generally when I use the 20/0.70 through this much liquid (water) I can clearly see the loss in resolution.
