I wanted to finally try out two objective lenses I purchased from a user on this forum: a Nikon M Plan 20x LWD and a Nikon M Plan 40x ELWD.
I mounted them on a cheap no-name microscope body that I mount my camera to directly (to the turret) and use extension tubes or a bellows to control the tube length.
This was taken only as a test shot, but I thought some viewers here might enjoy it. It was taken with continuous transmitted light (an LED lamp built into the scope). This is 28 frames manually advanced with the fine focus knob and stacked using PMAX in Zerene Stacker. The objective I used for this was the Nikon M Plan 40x ELWD. It's designed for a 210mm tube length, but I only used a 36mm extension tube (although the dovetail to EOS adapter combo adds another 20mm (approximately).
There appears to be some false colors, but otherwise I'm very happy with the detail. Not a bad lens at all!
