Caloplaca erythrocarpa
ralfwagner
Post by ralfwagner »
Hello,
this lichen grew on rests of a wall of the ruin of Fort de Buoux, Luberon, Provence, France.
- Habitus. Thallus thick, white, cracked, clearly limited. Photobiont coccoide green algae. Apothecia numerous, densely together, ca. 1 mm diameter, red disc , often with thalline exiple. Spores 12 - 18 x 5 - 9 µm.
Mediterrane on limestones, here together with Aspicilia calcarea.
- Some cross sections of the apothecium. It is remarkakable, that always two apthecia grow together. Staining with Lactophenol-Methylblue-Acidfuchsin.
- Spores 12 - 18 x 5 - 9 µm. This kind of spores are typical for the genus Caloplaca ans can serve as an identifying criterium. Staining with Lactophenol-Methylblue-Acidfuchsin.
Rylee Isitt
Post by Rylee Isitt »
Nice!
I took a fungi and lichens course not so long ago, but when it came to the lichen we didn't do much microscopic work beyond using dissecting microscopes.
I did look at a fair amount of spores for non-lichen fungi, and used them for ID, but didn't do any staining. Size, shape, number of oil drops, and ornamentation was more or less all we looked at.
I imagine the process is much the same for lichen? Do you get the spores from a simple scraping of the apothecia surface?
BJ
Post by BJ »
Ralf,
excellent as always - thank you!
Brian
ralfwagner
Rylee,
you are right, in most cases lichens can be treated like fungi, indeed they are fungi. You can get the spores from a simple scraping of the apothecia surface here, too. Another way is to press a little piece of apothecium between 2 slides and then add a drop of water and a coverslip to one of them. Instead of warter it also usual to mount in 15% KOH. This will clear the specimen.
The spores I am showing here were photographed directly in the one of the apothecium cross sections and then I isolated them digitally with GIMP.
@Brian: Thanks!
