Nebela collaris
gpmatthews
Nebela collaris
Post by gpmatthews »
Microscope: Zeiss Standard
Ocular: Zeiss KPL-W 10/18
Objective:Leitz 25/0.55 ICT NPL Fuotar
Substage: Leitz 0.9NA ICT
Sample from Monkmead Woods, West Chiltington, West Sussex, UK
15 images Zerene Stacker
Graham
Ferry
Post by Ferry »
It might be Nebela tincta, but the distinction between both species is arbitrary. An important characteristic is the presence of two lateral pores just above the neck (=N. tincta).
gpmatthews
Thanks for this -
According to the FBA guide* Nebela tincta should be yellow (maybe there is hint of yellow in the image?)and partially overlain with a smooth layer of organic cement. The Guide also mentions in respect of Nebela collaris that "Many surveys combine the species with N. bohemica Taranek. On balance I felt N. collaris was more probable than N. tincta. I think the two features in the image below may be pores, but they are lower down the test from the pseudostome than in the Guide's illustrations:
*Guide to the identification of Soil Protozoa - Testate Amoeba, Clarke, K.J., Freshwater Biological Association 2003
Graham
Ferry
Post by Ferry »
Hi Graham,
The color isn't very characteristic. Your arrows don't indicate pores. Pores should be on the very edge of the shell, at 1/3 from the mouth:
You can compare http://www.arcella.nl/nebela-tincta with http://www.arcella.nl/nebela-collaris.
gpmatthews
OK, thanks - if I find another, I'll try some new images...
Graham
Post by Mitch640 »
Wonderful work. Are the pores for water circulation?
Ferry
Post by Ferry »
We don't know what function they have. Some species have pores at the fundus, some have two, others have up to ten, depending upon the depth of the water.
