All with 20x/0.75 objective and DIC, last two staked images.
To get bright and shiny image try the following:arturoag75 wrote:Rogelio please stop otherwise i jump out of windows whit my scope ...and my 600D![]()
incredible shots!
just a question:
my canon does not give me pictures so bright and shiny like yours even if they are visually .... is there some trick? in addition to your skills and the microscope??![]()
best
arturo
Rogelio,RogelioMoreno wrote:To get bright and shiny image try the following:arturoag75 wrote:Rogelio please stop otherwise i jump out of windows whit my scope ...and my 600D![]()
incredible shots!
just a question:
best
arturo
- Avoid to shoot with too much water between the subject and the coverslip.
- Try to select the coverslip that you use. I use #1 coverslip and I try to select the ones with 155um or more (I use a Mitutoyo micrometer with 1um resolution), normally with a coverslip of 160um (you have 10um of play) you get very nice image quality.
Let me know if you need more details.
The image on the camara's display look beautiful; but when I convert the raw to tif it is not as on the camera's display so I have to adjust contrast. Normally I do the following:Cactusdave wrote:Beautiful image with very rich surface detail. Are you using a contrast or detail enhancing step, other than simple sharpening, during image post processing?
