Fulgensia fulgida --- the scrambled eggs lichen
ralfwagner
Post by ralfwagner »
Hello,
found this (in Germany seldom) lichen in France, Provence on lime rocks. The first picture shows why it is also named "scrambled eggs lichen".
- Habitus. Thallus up to bis 3 cm, upper surface yellow-white, rosett-like, loben at the margins, inwards coherent without schizidia. Photobiont coccoid. Apothecia frequent, 0,5 - 1,5 mm diameter, disc red with thalline exciple. Spores clubbed, 12 - 20 x 5 - 6 µm. Chemistry: Apothecia K+ purple, Physcion
On (dust impregnated)lime rock, in bright locations, kollin.
- Closeup apothecia and thallus.
- Cross section apothecium. Thalline exiple. Staining with Lactophenol-Methylblue-Acidfuchsin
- Cross section apothecium. Closeup thalline exciple. Staining with Lactophenol-Methylblue-Acidfuchsin
- Ascus with spores. Ascus 8 spored, amyloid, Teloschistes-type. Spores clubbed, 12 - 20 x 5 - 6 µm. Staining with Lugol.
discomorphella
Post by discomorphella »
Hi Ralf--
Great sections. Are these hand sections or frozen sections? Also, have you tried PAS staining on your lichens?
David
Very nice sections, thank you for sharing.
ralfwagner
Hello
and thank you for your nice comments.
@David: The cutting technique used is described here http://www.dr-ralf-wagner.de/TechInfo-englisch.html in detail.
No, I didn`t try the PAS method. Did you ever try it with lichens what results did you obtain?
discomorphella
Hi Ralf--
I've never tried PAS on a lichen, but it has given good results on macrofungi like mushrooms. I was thinking PAS-Alcian Blue or for fluorescence, maybe Calcofluor and Sytox Green for seeing the different components. If I have some time try I'll try that. I certainly have lots of lichen in the woods in Oregon and Washington...
David
