Diatoms
Diatoms
various diatoms
curt0909
Post by curt0909 »
#4 DIC is great. Your phase contrast is very crisp.
Thank you.
I leeched the aperture of a smaller diameter than the original which gives a higher contrast.
Very nice!
With smaller diameter, are you refering to condenser diaphragm in DIC or the phase ring? (the last one would be very extrange)
Ring of the phase, the diameter of a circle filling is reduced.
Marek Mis
Post by Marek Mis »
Jacek,
Very nice imagess. The fifth one, in phase contrast, is very good - extreme details and the contrast. I can't achieve such results with my phase contrast set. First of all the quality of your phase objectives is excellent.
Bets regards
Marek
Ecki
Post by Ecki »
Jacek,
I like the Phase Contrast shots a lot. Could you explain a bit more detailed what you did with the phase rings?
regards
Ecki
Translucent circle diameter is reduced from the original, so that got more contrast. The rings are made of foil with print ready on your computer. Do not know if I wrote understandable.
Very nice set, #5 is beautiful!
The pictures of the phase rings are the normal and the reduced or both are from the reduced version?
These are sample pictures. This is my iris to PH3 still working on it. To Ph2 is much smaller and transparent ring is about 1 mm thick. I had on hand just such a picture. I do not know if I understand the question?
Marek Mis
Post by Marek Mis »
Jacek,
Beautiful images again. Fragillaria is simply stunning ! Congratulations.
Marek
Thank you Marek
