Nassula and Frontonia
discomorphella
Post by discomorphella »
I was rummaging through a dish of pond water under the stereoscope when I saw a small pair of purplish protozoa swim by. It turned out to be a dividing Nassula that was almost ready to separate. There was another ciliate that was close by and I managed to pipet both of them up in the same drop. I am not sure about the identity of their friend, I think it keys out to Frontonia but I am not certain. I am sure that one of you will be able to assist however. The putative Frontonia then rammed the dividing Nassulae and broke them apart, and helpfully rolled one of the Nassula onto its side where I could get a good shot of its cytostome. The "friend" must have gotten some ideas from the Nassula, because when I finally caught him his nucleus was starting to look like it was approacing metaphase. Assuming that is his nucleus of course.
All photos taken with a BX-60, UPlanApo 40/0.85, variable mag changer and Variozoom eyepiece set at 5X with a 0.32X projection lens and a D300. All of these were flash pictures, with an SB-800 firing through the back of the Olympus halogen lamp house (Verzeihen Sie mir Professor Koehler...) to provide something very close to proper Koehler illumination with the flash. Flash synch at 1/320.
Has anybody had any luck culturing Nassula? I am looking through the literature but if anyone has any recipes...
David
]Image
Last edited by discomorphella on Thu Mar 22, 2012 1:12 pm, edited 2 times in total.
Wonderful photos!
I'm a little confused about the setup. I'm not reading anything in here about DIC, I am reading Koehler, and I'm also seeing a strong 3D appearance. I'm having trouble making sense of this combination. Is it DIC, or is there some strong oblique component to the lighting?
discomorphella
My bad, I left out the DIC components...the optical train should read
All photos taken with a BX-60, DAPO40 DIC lower DIC prism, UPlanApo 40/0.85, U-DICT Nomarski upper prism, variable mag changer and Variozoom eyepiece set at 5X with a 0.32X projection lens and a D300. All of these were flash pictures, with an SB-800 firing through the back of the Olympus halogen lamp house (Verzeihen Sie mir Professor Koehler...) to provide something very close to proper Koehler illumination with the flash. Flash synch at 1/320.
All images were color temp corrected with Nikon View NX and then background divided and scale bars attached with ImageJ
Thanks for catching the omission Rik, your internal image processor is still hard at work even after hours here....
David
Post by arturoag75 »
Really very nice shots :lol: !
arturo
Very nice set, I like a lot the first picture.
Bruce Taylor
Post by Bruce Taylor »
Definitely Frontonia (F. leucas, probably). The mouth and suture are clearly visible in the first pic.
Nice images! I love watching Nassula. :)
naturephoto1
Post by naturephoto1 »
David,
Really well done photos with outstanding detail.
Rich
discomorphella
Thanks for all your comments.
Bruce, is that Frontonia starting to divide? The nucleus (if I've identified it correctly) is starting to look like a metaphase nucleus in a standard histological preparation.
Thanks,
David
curt0909
Post by curt0909 »
Very nice. Love the colors
Bruce Taylor
discomorphella wrote:Bruce, is that Frontonia starting to divide? The nucleus (if I've identified it correctly) is starting to look like a metaphase nucleus in a standard histological preparation.
I wish I knew. I noticed the odd texture of that macronucleus, but don't know what's going on there. I did a quick scan of the literature on macronucleus division in Frontonia, but I'm afraid I don't know enough to draw anything useful from my reading.
