I'm not convinced about he "Encentrum sp" - may well not be, but here is a stereo pair of a smaller specimen seen from the side. It appears to be a grazing species,that creeps rather than swims.
The specimen was anaesthetised with dilute lidocaine hydrochloride solution run along the edge of the coverslip and then left to relax for a couple of hours (the lidocaine was in a throat spray containing mannitol which tends to seal the edges of the coverslip and prevent evaporation). Other species of rotifer on the slide did not relax, but this one did fairly well.
Graham
Your DIC set works very well, Graham. I am not sure of DIC is the best technique for making stereo images because of the highlight and shadows. But it is nice to see a rotifer in 3D. I hope you will be able to make more. The narcotizing technique seems to work well. I once heard that in the Victorian days they used Cocaine to relax rotifers. A pity that they removed it from Coca cola. Otherwise that would be the trick!
One little comment. The second and third image are a bit dark. I think they would look better of they were a bit lighter. Do you shoot in raw?
Wim van Egmond wrote:I am not sure of DIC is the best technique for making stereo images because of the highlight and shadows.
I agree the stereo is problematic. But I think the problem is just that DIC finds detail everywhere at every level within the subject. When the stereo is assembled, all those details produce a confusing "cloud" of features rather than becoming a relatively simple surface like the shell of a diatom. In the stereo rotifer, I get a clear perception of debris clustered in two planes, one in front and one behind the rotifer, but the rotifer itself makes no immediate sense to my eyes.
I too intitially had problems with the stereo, but found that it improved with studying and was pleased with how it enabled me to see the disposition of the cilia. There is, however, a lot of detail that is potentially confusing and a layer of bacteria on underside of the coverslip overlays the rotifer which doesn't help
I also noted the use of cocaine by the Victorians, also eucaine and more recently bupivacaine. Some have also used dilute alcohol, but everything I have tried to date tends to make most rotifers contract and stay that way. This was the only one that was in any way relaxed.
For stacks I tend to shoot with jpg, just because of the processing time. I find DIC a bit of a problem in terms of extremes of contrast - quite often you get very bright highlights but much darker background and shadows.
Graham
I agree that 'hard' lighting can be a real problem with DIC. It may be more so in older DIC implementations as Rogelio doesn't seem to have this problem, or at least if he has he seems to have more control over it. This may also be so of the PZO DIC condenser which seems to offer a lot of control. With my Diaphot DIC I have found that playing with all the possible factors, condenser height, condenser diaphragm aperture, setting of the lambda compensator and rotation of the recombining Wollaston prism, and carefully optimising each, gives the best chance of getting even and not harsh DIC illumination. On an old, and much used by previous owners, DIC setup like mine on my Diaphot, the variability of DIC illumination is a constant battle.
I discussed the "Encentrum" image with Eric Hollowday, our rotifer expert at the Quekett, and he tells me that this is in fact a Lindia species. This is confirmed by the trophi which can also be seen fairly clearly in the image.
Graham
