Swarms
Swarms
Post by Wim van Egmond »
I have not taken a single micrograph this year. First i have to organise the images I made last year. A lot of work. :( I had some trouble with uneven coloured lighting because of a damaged element in my microscope. Before I make new images I have to make sure my set up is workign better so i have as little post processing to do as possible. And start with a clean sensor. Here is a series of images of microbes that form a cluster. With algae you can use their phototaxis to concentrate them.
Wim
Post by Mitch640 »
These are just amazing Wim. Looks like you have the problem fixed. :)
Wim,
Wonderful set!
I would like to know the setup used.
Sort of torture to see all this micro-bounty at this at this time of year when my normal collection locations are exceedingly dull... :cry: :wink:
Jean-marc
Post by Jean-marc »
Beautiful set.
I would have the chance to see so much algae like yours.
JM
Thanks! This was with the not so perfect set up so I needed to correct colours shifts in some of the images. Although darkfield goes pretty well.
No need to feel tortured, Charlie, because these images are from last years summer.
I will see if I can post some images of my set up. Be patient. Many other things to do.
Wim
Marek Mis
Post by Marek Mis »
Wim,
Simply wonderful !
Marek
