Loxophyllum, Stylonychia and Naupliar
Here recent images:
1 and 2 Loxophyllum.
3 Stylonychia (I think it is Stylonychia) with 4 macronuclei.
4 and 5 Naupliar
All with Nikon TE300 microscope, Plan Apo 20x/0.75 objective, DIC, flash and Canon T3i mounted on the TE300 front port (2x).
Let me know your comments.
naturephoto1
Post by naturephoto1 »
Rogelio,
Stunning images and lighting. I particularly like the first three images and the first one has particularly nice orientation.
Rich
Post by Mitch640 »
Amazing images. I have never seen a Stylonychia in such detail. The polarizing effect even lights up some of the particles.
Rich and Mitch,
Thank you.
Tom Jones
Post by Tom Jones »
Rogelio,
Beautiful images!! :shock:
I'm presuming some of the reason you are able to get such stunning clarity across nearly the entire surface, is the fact that the organisms are more or less flat against the bottom of the dish. Since you are using DIC, plastic petri dishes are probably out. Are you using glass dishes, slides, or inverted slides with the coverslip on the bottom to eliminate the effect of the thick glass? I'm guessing inverted slides.
Tom
Super pictures, the resolution of the microfilaments in the first two is astonishing, really what we used to call 'research grade' in the lab. :D
Comment is superfluous, wonderful images, excellent
Tom Jones wrote:Rogelio,
Tom
I am using coverslip for both sides, the stage on inverted move in both direction together with what you put on it (on upright the stage move in one direction together with the slide, the other direction only move the slide).
Thank you for your comments.
Cactusdave wrote:Super pictures, the resolution of the microfilaments in the first two is astonishing, really what we used to call 'research grade' in the lab. :D
I am also amazed that I got that extrusomes so detailed, the kineties can be seen too.
Jacek,
