Tachysoma, Coleps & Colpoda
All with Nikon TE300 microscope, Plan Apo 20x/0.75, DIC, flash and Canon T3i mounted on the TE300 front port.
Post by Mitch640 »
Beautiful images Rogelio. It seems you have found the perfect microscope/camera combination. Do you find the inverted scope easier to use than an upright?
Mitch640 wrote:Beautiful images Rogelio. It seems you have found the perfect microscope/camera combination. Do you find the inverted scope easier to use than an upright?
The upright is easier with oil objectives.
With dry objectives the inverted gives you:
- The option to turn upside down the coverslip set (I use a coverslip as slide and then cover it with another coverslip) when the subject is to deep in the water.
- In some cases the detritus or other particulates float so they move to the top leaving the bottom more clear.
- Charles found that gravity help to keep the specimen closer to the bottom coverslip, so less water between the bottom coverslip and the subject.
Thank you for your comments.
