All with Nikon TE300 microscope, Plan Apo 20x/0.75 objective, DIC, flash and Canon T3i mounted on the TE300 front port (2x).
Pau, let me know if you trow it (to go and pick up it for me, joking).Pau wrote:Rogelio, Nice picture of stars collision, but be aware this is a microscopy forum and not an astrophysics one![]()
The quality your are getting is just incredibile. If you don't stop posting this beauties I'm going to throw my poor DIC scope to the litter and moving to another hobby (joking again)
Arturo, yes I shot in RAW.arturoag75 wrote:No words.....![]()
just a question: do you shot in RAW format?..your pics are so clear and brilliant that i've dubt on my T3 camera...
is there some trick in post production??![]()
best and congratulation for your job!
best
Arturo
Charles,Charles Krebs wrote:Rogelio,
These are great!
Very talented user, great equipment and set-up.
More than any of the images you have posted recently I think these also show what I had wondered about earlier... the benefit of having gravity working for you instead of against you. With an inverted microscope you have situations where, due to gravity, multiple key parts of the subject are right up against the coverslip. (This appears to be really obvious in your third image). With an upright you would be lucky to have one or two of the tentacles... 1) in the same focal plane, and 2) against the cover slip for best optical quality. Using wet mounts in an upright, gravity tends to pull your subject away from the best location for optical quality. Often you will have a considerable layer of water between the cover and the subject... and this can really kill the image quality of a high NA objective due to increased spherical aberration. (With live material I think this can also lead to more "flattened" and distorted subjects when the photomicrographer tries to minimize this water layer).
Most inverted microscopes I have seen are set-up with very modest (NA) condensers and no DIC capability, so it is quite a revelation to see your wonderful images.
