appendages on a Calanoid copepod
Franz Neidl
Post by Franz Neidl »
Sometimes I see Calanoids with appendages on their antenna. I would be grateful if somebody knows the biological function of these appendages and the species name of the copepod.
First picture: Obj. 40x, DIC, stack with 7 pics
Second picture: Obj. 10x, DIC
Franz
BJ
Post by BJ »
Hi Franz,
I think that this may be Calocalanus plumatus, but it is not a species that I have seen.
The consensus seems to be that role of these setae at the end of the antennae is sensing mechanical disturbances. Generally, chemo-sensory organs are concentrated at the base of the antenna, mechano-sensory at the tips and a mixture of the two along the length of the antenna.
The argument for mechano-sensory organs at the end of a long antenna is to isolate them from signals caused by movement of the copepod itself. The sensors then are to pick up movement of prey or predators. I would imagine myself that such a finely detailed structure would be to pick up precise information about small objects close at hand (ie nearby prey) - but I am not a physicist !!
Thank you for posting,
best wishes
Brian
Franz Neidl
Hello Brian,
I thank you very much for your interesting answer. I am really impressed that this calanoid copepod has such a sophisticated kind of "sonar" detection !
Franz
