"Could you give a brief summary about how you work once you have collected with the plankton net? How do you isolate and separate these subjects and get them on a slide? Is it simply done with a stereo microscope and pipettes?"
Hello Charles,
thank you very much for your kind words. I dont use the classical method with the stereo microscope, but I make at home a concentration from each sample with a cup-shaped planktonnet (meshsize 33 µm). Afterwards I give with a pipette two big drops on a slide and observe it on my microscope with the 4xObjective (this objective is essential for my work). If I find something interesting I cover the 2 drops with one coverglass (24x60 mm).
If I dont find something I clean the the slide and give two new drops on the slide...and so one.
If somebody wants I can describe better some of the details of this workflow.
Franz
