Stifling Science
- Tesselator
Stifling Science
I took these for another discussion and thought they might be interesting here:
Polyurethane Condom Stretched to 400% and photographed at 1,500x
My Spermatozoa In Relationship - at 150x
Interesting pictures indeed!
I assume these numbers must mean magnification on sensor? Otherwise the animalcule seems rather larger than the value quoted at Wikipedia: "head 5 µm by 3 µm and a tail 41 µm long".
So, what sort of optics do you use to photograph at 1500X on sensor?
- Tesselator
I dunno. I didn't really give it too much thought.
For 1,500x the Objective was 100 and the eyepieces were 15x. Although the camera connects directly on front without passing through the EPs it was about 50% the of the image circle seen through the EPs. You can see the Olympus camera mount on front of the IMT-2 here:
Or view p.3 http://www.alanwood.net/downloads/olymp ... ctions.pdf
The multiplier just below the objective holder ("Magnification Changer Ring") was set to 1.5x and setting the light-path selector knob to "OM" displays an overlay that says "2.5X". Then of course the sensor is 1/2 the size of FF... And on top of that I reduced the images to 30% of original and cropped them by about 50%. But, it didn't seem right nor accurate to solve using all those magnifications and percentages:
100 x 15 x 1.5 x 2.5 x 2 ÷ 3 =
...so I just put 1500x without trying to figure anything out. This does sound like something Leeuwenhoek would do for sure... LOL
The 150x was taken using a 10x Zeiss objective.
Got it, thanks.
So, paraphrasing, "This is a small part of the frame that you'd see through the eyepieces at 1500X."
It's hard to compute the scale using this sort of setup, and of course what each viewer sees depends on his monitor size anyway. Scale bars are the way to go. If you plan to do very much microscopy, I suggest to just get a "stage micrometer" (essentially a tiny ruler on a microscope slide), image it using the same optics, then use Photoshop to overlay the two images and construct a scale bar.
Stage micrometers are cheap and easy to get these days. Just search eBay to find new ones for $29.
Interesting images, nonetheless.
- Tesselator
- Tesselator
Yeah, I did that but they're like $25 and up and that's just too ridiculous for a $2 to $5 item. In Japan I did actually find one but it's a bundle of 10 of them for about $60 : http://page9.auctions.yahoo.co.jp/jp/auction/k135473640
At $6 a piece for something MUCH better than what I saw on ebay it's almost tempting but still... a 25 to 60 buck pay-out?? There's gotta be another way.
Sure -- just do what Mitch says to calibrate your system with a low power objective, then scale up for other objectives in proportion to the objective's magnification. It's rather more tedious, but it works OK. Just another example of "time is money", I guess.Tesselator wrote:There's gotta be another way.
By the way, those micrometer slides are typically chrome plated on glass, then covered and cemented for use with high power objectives that need to look through cover glass. It'd be an interesting exercise to make money by manufacturing and selling them as individual units at $2 to $5 each. On the bright side, I suspect you'd have no trouble cornering the market if you can figure out how to do it.
- Tesselator
- Tesselator
OK here it is. Full width strips from 4 images scaled from 4000 pix wide to 1000 pix wide (25%).
This image is from a Panasonic GH1 in 4:3 mode which has an active area of 17.3x13mm according to Camera Labs dot com
- Tesselator
Should be easy enough.
Objective: 4
Optical Magnification at imaging sensor: 10.4x
Screen Magnification PR 1:1 (23" LCD): 312x
Screen Magnification after 25% image scaling: 78x
Objective: 10
Optical Magnification at imaging sensor: 26x
Screen Magnification PR 1:1 (23" LCD): 780x
Screen Magnification after 25% image scaling: 195x
Objective: 20
Optical Magnification at imaging sensor: 52x
Screen Magnification PR 1:1 (23" LCD): 1,560x
Screen Magnification after 25% image scaling: 390x
Objective: 40
Optical Magnification at sensor: 104x
Screen Magnification PR 1:1 (23" LCD): 3,120x
Screen Magnification after 25% image scaling: 780x
Objective: 100
Optical Magnification at imaging sensor: 260x
Screen Magnification PR 1:1 (23" LCD): 7,800x
Screen Magnification after 25% image scaling: 1,950x
And then multiply everything times 1.5 when the mag dial is set to 1.5x of course
Objective: 4
Objective: 10
Objective: 20
Objective: 40
Objective: 100
