Small Crustacean custom DIC
curt0909
Post by curt0909 »
A very small crustacean from a puddle just outside Pittsburgh, PA USA. I'm not sure the species.
equipment: Leica Galen III stand, Nikon bd plan 40x, 2x teleconverter, custom dic. Probably pseudo-dic at this time. I'm still making adjustments.
Videos
http://www.youtube.com/watch?v=n6EV5wzM6tI
canon 600d 3x zoom http://www.youtube.com/watch?v=_OVy1d4z ... e=youtu.be
Re: Small Crustacean custom DIC
curt0909 wrote: Probably pseudo-dic at this time.
Not sure if it is true DIC, perhaps some kind of oblique "VOILA" effect:
http://www.photomacrography.net/forum/v ... 5934#25934
http://www.photomacrography.net/forum/v ... ight=voila
The second image is interesting, you are certainly getting lots of 'relief' detail on the subject, but you have the typical problem of (very in this case) uneven field illumination which is a characteristic of mismatched DIC combinations and oblique illumination. As Pau says it's not clear if this is true DIC or an extreme example of the form of oblique illumination that Graham Matthews called VOILA that Pau references.
curt0909
Post by curt0909 »
Yes the gradient is pronounced in these images. Its definitely caused by the dic prisms but its greatly increased in post processing by using contrast, curves or levels adjustment. So far the system is producing 3d relief and optical sectioning. I still have to work on increasing contrast... After some research I believe this is a copepod. Does anyone know?
Edit: Its a quick fix in post to correct the gradient. Here are the updated versions
