2.19 gigapixel - Halyomorpha halys
Hi everyone. My name is Curt. I've actually been reading this forum for quite a while but this is my first time posting. Thanks for having me. I want to say thanks to Rik for Zerene Stacker and Charles for some excellent posts and articles that helped me get started in this hobby. -Curt
http://photosynth.net/view.aspx?cid=540 ... 8f5a361f35
Technically its 1.1 gigapixels mirrored laterally
Thanks for the link to your remarkable synthesized photo.
It would be great to learn more about how you obtained the images used to create this photos - do you have a link to your photo rig, etc?
I enjoyed roaming around the photo at the link provided - a different approach to the usual static 2D photos we normally work with in macro forums.
-Phil
"Diffraction never sleeps"
Thanks Rik and DQE. Mitch, it gave me some trouble also but after some searching I was able to get it to work on my 64bit machine by editing the permissions in registries.
Rik, if they hit Oregon as badly as they hit PA your friends have reason to be worried. They didn't have the numbers this year that they had last year. They cause millions of dollars in damage to orchards. Very few predators, the skunk is the only one I'm aware of.
But I chose the stink bug out of convenience. After a small success shooting a 120 megapixel panorama of a grasshopper a few months ago I wanted to try a higher magnification and a much larger end image. I chose the stink bug for a few reasons. They're plentiful in Pittsburgh. As the weather cools they're drawn to homes to stay warm. They're small, which helped keep the size of the image manageable. This specimen was smaller than a penny. Lastly they're relatively flat which is helpful with focus stacking and merging. I originally started shooting with a 2x teleconverter but after using over 100 megapixels on the head alone I decided to cut my losses and reattempt without the tc. I'll post that image when I get a chance. There was a lot of trial and error involved. I'll post a photo of the set up when I have some time.
- Cactusdave
I had no problems using Photosynth with 64bit Windows 7. I use Photosynth regularly to host panoramas and large images and like it.
Impressive panorama, I just can't believe how far you can zoom into it. Very interested to read about your technique too. I understand why you haven't tried to remove the halos on the completed image, you need a lot of ram and a very fast machine to work with these gigabyte images full size in Photoshop. You might consider de-haloing a downsized image though, or de-haloing the relevant stack outputs before stitching.
I guess making an image by duplicating one half and flipping is OK if your subject is really symmetrical. It wouldn't work for me making panoramas of stacked images from a microscope slide preparation. Those old mounts I use are just never wholly symmetrical.
Thanks to Rik's note, I benefited from scrolling down and seeing the technical info about the photo.
Surely a 1 Gigapizel image from almost 3000 photos is the new world record!
Using Firefox 7.0.1 and Win7 64-bit, I was able to zoom and scroll, etc, fluently and without issues. It worked even more enjoyably when I placed the browser and the photosynth site options into "full screen mode", enabling me to use almost all of the real estate of my monitor on the image.
I really do enjoy this interface for this type of image. Being able to quickly and smoothly zoom in and out is very helpful.
What is this viewing software doing with respect to zooms? Does it on demand automatically reinterpolate the original master image set so as to provide maximum or maximum viewable detail to the user's monitor? That's what it feels like but I'm of course just guessing. No need to respond - I just need to read the photosynth site info, of course.
-Phil
Conversation at a recent technical conference:Mitch640 wrote:Bummer, I can't see it. Why would Microsoft make anything new that can't run on 64bit?
Chris: I'm running Win764 bit now, very pleased with it. Looked at the IE10 preview... puzzled that IE9 32bit is the default on Win7 64bit, why is that?
MS engineer: You can set the 64bit version as your default if you want
Chris: Why doesn't it ship like that though?
MS engineer: *ahem* silverlight *ahem*
Just in case it might help someone:
I am running Win7 64-bit.
With Firefox v7.0.1 and the Silverlight add-on, v4.0.60831.0. I can see and manipulate the Photosynth image linked above.
Hope this helps. There are alternatives to IE, which I also run for those occasional instances where I can't get Firefox to function effectively.
-Phil
After I downloaded and installed the Silverlight .exe, I was able to see it in both IE 9 64bit and Firefox 64 bit. My problem was, When I went to the page linked above, the nag screen said I was running 64 bit and would not even let me click on the button.
Once I downloaded and installed it manually, both browsers worked fine. Silverlight is a Windows app, it's not browser specific.
Not really sure how all these things work together, but the optional Firefox SIlverlight add-on somehow makes Silverlight images, etc, work within a Firefox tab. Otherwise, I think I'd have to view it from IE, which I assume has Silverlight built-in or otherwise enabled.Mitch640 wrote:After I downloaded and installed the Silverlight .exe, I was able to see it in both IE 9 64bit and Firefox 64 bit. My problem was, When I went to the page linked above, the nag screen said I was running 64 bit and would not even let me click on the button.
Isn't SIlverlight both a standalone viewer as well as an optional browser add-on?
Just commenting off the top of my head - haven't looked into all this in great detail.
-Phil
CactusDave, I have a custom machine I built earlier this year. I have an intel i5 2500k sandybridge processor overclocked to 4.6gHz. I could use more ram. With my current system I can edit small changes on the full image without lag. Changes to a large selection do take some time for processing. This insect isn't really symmetrical. You can see the wing on the posterior is not correct. I'll have to go through my original photos and see if I have the photos to graft the right section of the wing on the photo.
