"Leaf Insect"
gpmatthews
"Leaf Insect"
Post by gpmatthews »
This is an image from a slide in my collection. The slide is simply entitled "Leaf Insect". If anyone can tell me the identity of this insect I will be most grateful.
The image is a composite of six images stitched with MS ICE. I have not used stacking.
Microscope: Zeiss Standard
Objective: Leitz 16/0.45 NPL Fluotar ICT
Ocular: Zeiss KPL-W 10/18
Substage: Leitz ICT 0.9 NA
6 images stitched, MS ICE
Graham
Nice image Graham. The flattened shape and general appearance, with the hooked feet suggest a parasitic louse of some sort. Can't see the mouth parts in this dorsal view. The leaf-shaped appendages are fascinating.
gpmatthews
- wasn't absolutely sure,but wondered whether this long feature is in fact the piercing mouth parts of a true bug:
(this is a nearly full resolution crop)
interestingly, you can see some striped muscle central left on the central axis
Graham
gpmatthews
Here are some more details:
The stitched image above, although viewed from the dorsal aspect was in fact effectively an optical section on the ventral side of the preparation, hence the structure I suspect to be mouth parts is indeed on the underside of the specimen. Here is an 8 image stack using a x40 DIC objective:
and here, using a x16 DIC objective is the dorsal surface of the abdomen:
Finally, as the feet were commented upon, here is a 16 image stack of the feet:
All stacks using Zerene after application of a dust map.
Graham
Harold Gough
Post by Harold Gough »
I think it is a hemipteran nymph with hairs highly modified as plastron scales to grip an air bubble.
Harold
The images are excellent!
gpmatthews wrote:All stacks using Zerene after application of a dust map.
Can you say a few more words about the dust map? What software did you use to do that?
gpmatthews
Thanks Rik - I used Helicon Filter.
Graham
Post by Mitch640 »
Very interesting images. It's pretty easy to see why it's called a leaf insect. That guy has his own leaf collection. :)
Very nice!
